My spa is plaster, 750 gallons separate from pool filter system. All of a sudden the pH keeps dropping to the 6.9/7 level frequently. I have not been using spa due to the heat. I use chlorine and this has also started to run quite low. TA 90, CH 275. Borates 35
I have been running air pump to boost pH but this is transient. Added some Borax and this also has been a transient response. My FC has been from 0-3 using an inline chlorinator. I have been adding bleach to raise FC as needed. Water looks fine, no algae.
What would cai=use this all of a sudden and how should I deal with pH and FC?
