I've done so much research my brain hurts. I'm a dummy when it comes to pools so I hope you can help. Yesterday I replaced the flapper in the check valve. Spa was again drained to pool level when the pump is off overnight. Q1: Should I replace the inner workings of the Jandy valve to the spa on the left? Q2: Do I have the valves set properly for normal pool operation so that I have circulation from the pool returns AND a decent amount of water spilling over the spa when the pool is running? This is all the same plumbing etc from when we bought the house in 2014.
Any help you can give on the spa draining when the pool is off, is GREATLY appreciated! (I'll save my question about the spa Venturi system (no pump) not putting air in the spa jets for another time. It's not worked right since we moved in. SO FRUSTRATED)
