- Jul 6, 2016
- 40
- Vinyl
- Intex Krystal Clear
I put in a 12'X24' Intex & built decks on both ends back in July of 2016, I built & maintained the pool with much help from this forum, I did not ask many questions because I found most of the answers I needed just searching the forum & using Pool Math. What a Great site this is I would have never gotten a pool due to fear of maintenance if it weren't for TFP.
One of the mistakes I made on my initial install was using standard pavers under the legs and I have since found many post on not doing that but I somehow missed that on original research therefore I had a couple crack and sink a little well due to that I ended up with a low corner which has continued to sink due to water always splashing out of that corner and now rotted the legs out on that corner so time to replace, this pool has doubled in cost since my original install and is a little small, I do not want an inground pool due to the trees on my property that make it very private but in turn load this AG pool up with leaves I can't imagine what it would do to an IG.
Since I am land locked between the 2 decks I built & I do not want to start over there and really don't want to move the deck any closer to the patio I have decided to build a custom AG pool and I am finding very little information on this so I will start with some details & questions and if I go through with it I promise to add some pictures and details as I go.
I am planning on building a 14' X 24' above ground with a true water depth of 52" the frame will be 2"x4" 14 ga tubing with the top rail laid flat & the bottom rail laid on edge I will use a 2"x4" tube post every 20" to attach & support the top & bottom rail & sheet metal, the sheet metal will be 41-9/16" wide (because that is how they sell it) so it will overlap on every seem at a post there will be 4"x8"x16" paver under each post, I plan on using the dense foam coving at the base, pink 1" foam board under the floor & angling a 2x4 tube at each corner since the liner guy said it is almost impossible to keep a square corner in place. I also plan on using the old Intex liner under everything as my "protection" layer since it is so thick. I had upgraded my Intex to the 2150GPH pump, larger sand filter & SWG combo at the end of 2019 so I plan on using that to start with and save a few bucks then when it dies which I hope will not be till after the 2022 season I will upgrade with better stand alone equipment.
Now for the beginning questions:
#1 I installed a Hayward wide mouth skimmer a few years ago (best mod & money ever spent) so I will reuse it on the new pool, I do not want the equipment on the North side of the pool like it is now due to being an eyesore so I am putting it on the South side of the Pool, where I am located our prevailing wind is out of the South 11 months of the year I know from research most recommend the skimmer opposite the prevailing wind & I can attest that works great but given my situation should I mount it on the South side or would it be worth it to run plumbing either under the pool or around it to keep the skimmer on the South side? I am worried about the additional length of pipe for the pump to deal with & if under there will be plumbing that is not easily accessible if I do ever have a leak.
#2 I am thinking about building the walls a little taller & put a taller liner in then what I need for the depth I want so there will be less splash out when the grandkids are jumping in & out & acting a fool, the only disadvantage to that that I see is when doing pool maintenance I will be reaching over a taller wall but I plan on building a bar/catwalk on at least the North side so I wont be reaching over that anyway & will probably do the same on the South side, is there any reason not to have an extra couple of inches of the liner above the water line? based on the liner form it looks like the cost would be the same to build a 54" or 56" liner.
#3 how close to the top edge of the frame should my liner bead be?
#4 is there any reason I should not build this pool?
I am sorry this was a long read & I left out a lot of details to keep it as short as possible but I promise I have really considered this long & hard, I believe I will come in around $3,000.00 & several man hours on this but I used to be a professional welder & fabricator and I enjoy building this stuff so the time is not such a big deal, I think this will be a permanent pool with some painting and a little extra maintenance.
I included some pictures of my current set up for reference, I do plan on demoing this pool next week.
Clint
Clint
