Unless things have changed, if you want individual panel monitoring you have to pay a couple of hundred extra for enlighten manager over the normal "my enlighten."
I can see the panel by panel output for my system which has a SolarEdge inverter. At least I can get that info on the SolarEdge website and apps. This info doesn't appear to be available via their API to put into other systems or easily download yourself.Unless things have changed, if you want individual panel monitoring you have to pay a couple of hundred extra for enlighten manager over the normal "my enlighten."
Wow - it is amazing to think that I use 30X more electricity than you do! How has it been to live without AC this summer - I am assuming the Ottawa has been about as hot as Toronto.
What kind of batteries do you have? Do the Tesla PowerWall batteries make sense for you?
I may have... I don't have the access yet, but my buddy pulled it upon his phone and we played with it a bit when we tested the system.
- Tesla is making energy storage sexy to the masses, and this is a good thing...
68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
My average daily usage over the last month is about 78kw not sure if that's a lot or not.. and how that translates into what I need for panels.
78 kWh a day is a lot. I would suggest you start by finding ways to bring that down...energy conservation gives a greater ROI vs energy production from a PV system.
+1 on conservation, a rough guess is your array would have produced 1500ish kWh last month while your use (78x30) is more along the lines of 2400kWh. Usually in spring and fall, production outpaces usage, so if you have a net metering agreement you will be in good shape.
That's 160% of tlevy's average consumption!I have a kill-a-watt meter that I used to check out plugged in appliances. One of my big ones was an old plasma tv that used almost 300watts while it was off. That was an 8kWh reduction a day just like that.
I am not sure how I can... I leave the house at 80 all day.. drop it to 74 in eve (just made that change it was 72) and 76 over night... and then 74 in morning before I get up... All my lights are LED pretty much except a few flourescents.. I live alone.. 2000 SF House.. but it was built in 1964... so I am going to put additional insulation in the attic and get a solar fan as well.. I need to insulate my garage.. although I don't heat or cool that... all my windows are new and double pane..the last thing that I can think of is my water heater which I am going to get a Hybrid. All my appliances are brand new, fridge, washer dryer etc.. Samsung and energy efficient..
Any other suggestions?
Well you seem to have much of the big stuff taken care of.l, especially if you plan on upgrading water heater (electric/gas?), and improving you insulation. How do you heat your house? Do you have an A/C unit? Are you on city water or a well?
The rest of it boils down to things like TVs, PS4s, microwaves that are plugged in, computers, etc...all those phantom loads, and so on. But...it is always amazing how much it all adds up!
I'm all electric in my house. Heat pump/ A/C and city water.
Its up and running now, just no net meter for a month... Here is a link to the video of my meter going backwards and giving an error code..lol.. with the A/C on!! .. Instagram
I'm producing 42.5 Kw a day right now... - does that sound efficient or expected with the system I have?
With my A/C not running, I produce more than enough power... so, I'm thinking of setting up my A/C run time for the times I make the most energy... ??
