thanks Ahultin and Dirk. you are right, I don't have a full understanding of the plumbing--any tips on how to create a schematic. should i switch On/OFF one valve and check what happens?
No need, we can probably help you with that just by see the drawing. Draw an oval for each valve. Draw rectangles for your pumps. I big circle for your filter and a big square for your heater. Then just connect each shape with lines, to represent the pipes going in and out of each of your components. Draw a horizontal line to represent the ground, and show pipes leading into the dirt as leading into that straight line. Add anything else you want to understand better. Label each component (pump 1, pump 2, valve, heater, etc). Easy. Just be careful you draw the lines correctly and not to leave any out, otherwise our advice will be wonky.
If you have to cross lines because of the way they'll intersect, that's fine. If two pipes join, like with a tee fitting, then draw a big, black dot to represent that.
Then later we'll help you fill in flow direction arrows. Once done, you'll transfer all your "chicken scratch" to the actual pipes: arrows indicating flow direction and words describing where each pipe goes, what each valve does, etc. It's everything the plumber or previous owner should have done. If you're like me, in a year when all this "learnin'" starts to get a little hazy, you'll appreciate your work, and all the labels you added to your plumbing.
And ideally you'll come away from all this with a better understanding of what all the valves do and how to adjust them. And, of course, what might be wrong with your solar plumbing. Usually we can do this from pics provided by the pool owner, but you've got such a jungle that a drawing will be safer.
