Typically I use a blue solar blanket.
At the end of the season I ended up getting a clear blanket.
CYA is 40
I keep chlorine levels steady (so I believe)
I found the clear solar blanket I am getting some surface algae.
Is this something to do with the clear blanket, or is this just circumstance?
I thought maybe the amount of light getting through May be using up more chlorine with the clear one
I had a pretty good system going until
I swapped blankets.
I assume more light gets through and burns off more chlorine.
CYA is 40
I swapped blankets.
