WOW! That is something about the plaster being "bad". I wonder if the plaster manufacturer is helping the PB with the extra costs he incurred from this and that mess.
I am so glad things are looking up for you!
Now lets talk about how your water testing is going. Have you run the numbers yet?
Yes, I ran them the first day, and it's funny you should ask...lol. We are on well water, but had two filters set up. One at the source, and another towards the end of the hose. Our water, without filter, has a high iron content. .
So, here I am thinking everything will be just fine. I pour in the chlorine, and the pool turns swamp green in front of my eyes. I seriously about freaked out. I showed it to my husband, and he wasn't thrilled either. So, I got on TFP and started looking things up. Basically, I concluded it was the iron. Even with the filters, something didn't work correctly. This has never happened to us before, so I was sitting there thinking "Man, there goes me taking care of the pool now!" My daughter was going to town (we live in the country), so I had her take a sample of pool water by the pool store. I'm happy to say that for the most part, my results on everything matched theirs to a T. Since It was only my second time using the kit, I was pretty happy. I also had them to check for metal/iron. They said there was none. I saw somewhere on here to not take that reading to heart, there could still be iron. Thank goodness for that post! They sent me a list of a ton of stuff that must be added to the pool. They wanted to me put in two gallons of muriatic acid when my ph is just 7.2. That worried me about all the abalone. Then, they wanted me to put in 8 jugs of liquid chlorine and 2lbs of Stop Yellow (whatever that is). Then to add a water clarifier as this would make the water murky. They refused to believe it could be metal. I had my daughter pick up 3 quarts of metal control by Jakes, and not get the rest. She said they were mad. She got home, I added the metal control following the instructions, and my swamp pool turned perfect blue in less than an hour. I know it will take further maintenance, and plan on discussing options for filtering out the iron or just maintaining a sequestrant. I'm just so glad I didn't go the other route and looked on here first. I've attached some pics that were taken just hours apart.
Kim
