I’ve posted about my small union nut leak in the past, but now my temp fox has failed…which I expected it to at some point…anyway…
Question… I have a small leak at my Jandy pump union. It’s a slow drip like a drip every 5 seconds, no leak if pump is off. I’ve ordered a new union nut but it’s going to take a week.
The leak is caused by a small gap between the pipe and the pump. Either the pvc going into the union wasnt cut straight making the union sit crooked creating the small gap ( 1/8 in on one side) at the pump or maybe the fact the pump wasn’t level?
The pipe leading to the pump was sloping down towards the pump. Is that correct or should it be level?
Am I going about it the right way by cutting out the pvc, rejoining it and putting on a new union?
Retightening the nut worked for a while but no longer.
I also have some flex pvc in my garage…should I use that in case I need a little bend to make a solid connection? It seems like the original pvc is just slightly off.
I hope I made sense….
Thanks!
Thanks!
