Today, I noticed small black spots in some areas of my plaster (please see the photos). I tested the water and here are the results:
FC = 1
pH = 8.2
TA = 80
CYA = 50
Based on the results, I know that the chlorine level is low and I need to add chlorine. I am wondering if the black spots are algea? Would you please give me some advice how to treat it? Do you recommend me to SLAM the pool? Is the SLAM target FC is 20 (I would like to know if the SLAM level is 20 in order to use my Pool Math app and calculate the required Bleach Chlorine to add to the pool).
Thank you.
FC = 1
pH = 8.2
TA = 80
CYA = 50
Thank you.
