One of the things that should be added to the procedure is to remove all equipment, hoses, fittings, etc... from the pool during slamming process, especially for black algae. If you can not see it to brush it, it will keep consuming the chlorine away. Once I removed everything I could from the pool, the process sped up quickly. All these years my Aquarite always made just enough chlorine and I thought it was because the size of my pool. This past August I did the slam due to the black spots on my steps with all the extreme helpful advice here, correctly for the first time. Now I realized that all those hidden black spots in the hoses, the fittings, the fountain and the Skimmer Plus had been eating my chlorine all these years. I now can set the output of my Aquarite as low as 60% during the peak summer temp and maintain at proper chlorine level easily.
