9/4 4:45pm FC 14.5
9/5 10am FC 13.5
9/6 4pm FC 8.0
9/7 8am FC over 5.0 (Chlorine Test (OTO))
9/8 815am Added 2 lbs CYA to get if from 30 to 60
9/9 9am FC 8.5 Also added 1 lb CYA to bring CYA from 60 to 75
9/10 730pm FC 7.0
9/11 Added 4 boxes of Borax and 112 oz of Acid to offset the PH and TA rise.
9/7 8am FC over 5.0 (Chlorine Test (OTO)) The FC was unknown since I used the OTO test on this day. The OTO only measures up to 5.0
The CYA was at 30 during the SLAM. The daily FC test was results from after the SLAM. The SWG was off most of time during these results because I was letting the FC drop to the recommended range of 4 to 5 ppm. I only had the SWG running on 9/8 for 5 hours.(Pump was on for 12 hours daily). I noticed that the FC jumped up to 8.5 so I left the SWG off a few more days until the FC dropped to 5.0
The SWG does not have percentage. Only can be adjusted by hour increments, 2 hours to 12 hours, plus a boost mode setting.
The FC never dropped below 5.0. And it passed the OCLT for 4 straight days before I decided to stop the SLAM. I think it is safe to say the Chlorine level is not the problem here.
