When was the last time it was cleaned?
What was the clean filter pressure and what is the filter pressure now.
It may be best to backwash and recharge the filter now -
and during the SLAM Process anytime the filter pressure is about 25% above clean pressure.
And after your
SLAM Process is fully complete, do a full filter teardown to get all remnants of algae and dirt out. This way, you start the actual swim season off with a totally clean filter.
In San Dimas, you shouldn't be closing the pool for the winter - just keep it open, vacuumed and balanced. In the winter, it takes very little time, effort or chemicals to do so.
You've had a lot of rain in SoCal this winter. You really need to drain water off well before the pool overflows.
Post a full set of current test results from your TF-100 and we can go from there.
