Pool renovation completed July 2022 with Diamond Brite plaster. I have a 20,000 gallon pool/spa combo. Spa had slightly visible green algae only on the wall above the seat. I changed the filtration to Spa ONLY (~ 750 gal capacity spa). CYA @ 30; adjusted Ph to 7.5 and SLAMed to 12 ppm using liquid chlorine. Brushed once per day throughout process.
5/9/2023: Cl 15 ppm.
5/10: 11:00AM - 7 ppm; 1:00PM - 11 ppm; 2:20ppm - 8 ppm; 3:30PM - 13.5 ppm; 5:30PM - 10 ppm.
Changed SLAM target to 16 ppm because when retesting CYA, it might be as high as 40 (so difficult to judge exactly).
5/11: 8:30AM - 8.5 ppm.
5/12: 9:00AM - 12 ppm; decided to drain spa and allow dry and sun to kill algae.
5/13: brushed empty spa and then refilled. Green looks better, but still slightly visible. Changed filtration to Spa and pool as I don't want to create a problem in the main pool! Backwashed DE filter.
5/24: Begin SLAM process again (Target 16 ppm and Ph @ 7.2) with filtration to Spa ONLY @ 11:00AM; 3:00PM - 15 ppm; 8:40PM - 10 ppm.
Each subsequent day, I switched filtration to Pool ONLY for a few hours while the Spa was 'soaking' in SLAM level chlorine, then back to Spa ONLY. Brushed Spa each day.
5/25: 8:30AM - 6 ppm; 10:00AM - 21.5 ppm; 4:30PM - 10 ppm; 6:15PM - 15 ppm.
5/26: 9:00AM - 9.5 ppm; 12:00PM - 17 ppm; 2:30PM - 10.5 ppm; 4:00PM - 15.5 ppm; 6:00PM - 11 ppm; 8:30PM - 14 ppm.
5/27: 8:30AM - 11 ppm; 9:30AM - 22 ppm; 12:00PM - 18.5 ppm; 2:30PM - 14.5 ppm; 3:45PM - 12 ppm.
5/28: 9:00AM - 13.5 ppm; 11:30AM - 17 ppm; 2:00PM - 13 ppm.
5/29: 9:00AM - 5.5 ppm; 11:30AM - 17 ppm; 2:00PM - 15.5 ppm; 6:15PM - 11 ppm; 8:15PM - 14.5 ppm (performed Overnight Free Chlorine Test).
5/30: 7:30AM - 8.5 ppm. Emptied Spa at Noon, again hoping dry and sun will resolve problem. It seems in certain lighting, I can ever so very slightly still see green. It is difficult to accurately visualize, but OFCT really tells me there is still active algae. Water has been, and remains, crystal clear.
I believe I have done a pretty good SLAM procedure, but the chlorine continues to be rapidly consumed. The 'drain spa and let dry/sun kill the algae' was my personal invention -- as I just didn't know what else to do. Spa is still empty.
Anyone have any ideas or suggestions? Greatly appreciated!
