When I'm SLAMming, should I shoot higher than my SLAM target so that it doesn't slip lower than that? Is there a certain amount below that SLAM target that I need to avoid hitting? For example, if my CYA is 40, then my FC minimum is 3, FC target is 5-7, and my SLAM target is 16. But if I dose my chlorine to get to 16, then it will be 13 when I check it later . . . so should I have put enough chlorine in to get it to 19 instead?
