FC and TC should be the same. If not, you have chlorine lock.
This is not true. I have a cover and regularly have .5CC with the cover on. When I remove the cover for 1/2 hour my CC will go to zero.
“Combined Chlorine” is a generic chemical term for chemical compounds formed from the reactions of chlorine with organic and biological contaminants in pool water.
Chlorine, and specifically the active chlorine compound hypochlorous acid (HOCl), is a very powerful oxidizer. Oxidizers, in chemical terms, take electrons away from the molecules that they oxidize and, in the process, break those molecules down into different compounds. The most common forms of combined chlorine found in swimming pools are those compounds where chlorine has reacted with nitrogen-containing chemicals in human bather waste (sweat, urine, etc).
www.troublefreepool.com
And when your CYA is too high, any chlorine above what it can stabilize is inactive, and it makes the test appear to be less than it actually is.
Not sure what to make of this statement. The cyanuric acid concentration determines the amount of active chlorine (hypochlorous acid + hypochlorite ion) available in pool water. This is why the CYA level is so critical to know and why TFP teaches that there is no such thing as an absolute FC level which is safe; the safe level of FC is determined by how much CYA is in the water.
This thread presents my findings so far on pool water chemistry including the following: More Accurate Calcite Saturation Index (CSI) to replace Langelier Saturation Index (LSI) Calculation of ppm HOCl (disinfecting chlorine) at various levels of Total Free Chlorine (FC) and Cyanuric Acid (CYA)...
"The other thing people do is test the water and determine they need to add chlorine. However, every time they test the water, it keeps reading low, no matter how much chlorine they add. This means that your CYA has it locked up."
Read the pool water chemistry and chlorine lock threads. If that happens, you have let your FC get to low for your CYA and have algae in the pool that consumes the FC. High levels of FC can eradicate the algae. See link-->
SLAM Process
The best way to beat it is to partially drain the pool to lower CYA. I know people who have not kept their CYA levels low, and end up with a green pool, over and over again. Then they have to shock the heck out of it, but the problem just keeps returning.
This is true, reducing CYA makes it easier to SLAM a pool and get rid of algae. They get a green pool at high CYA levels because they did not maintain their FC appropriately for their CYA...follow the recommendations. Link-->
FC/CYA Levels
