Was the water circulating before you tested?
What do you mean? I run the pump 24/7. Is that what you're asking?
I'm not even out of the woods on the SLAM yet, so this might be premature, but if you have a newbie like me who is anxious to switch exclusively to the TFPC approach but who also inherited 37 lbs of 3" trichlor pucks, what is the role, if any, of those pucks going forward? I don't want to waste them, but also don't want to fall off the TFPC wagon out of the gate. Ha. Do they store reliably enough that I could use the bleach approach exclusively for a month or two until I am a little more experienced, and then introduce those to the "tool belt" a little later, on a limited basis, or is it "use 'em now or lose 'em" for the pucks?
Can finally see outline of pool drain.
yay!
What does the 2FC loss since late last night mean?
Only 2 things are responsible for loss of chlorine. the first is sunlight and since this was an overnight loss, you can assume that wasn't it. the second is organics. there's something living, growing in there that has consumed your chlorine.
Quick question on the cya test. Have you done it outdoors with the sun at your back yet?
If not you should do that when you have time / sun. It can make a big difference in the reading.
Bleach is heavier than water and tends to sink when you add it. Are the light patches where you have been adding bleach? Are you adding the bleach slowly in front of a return? You might want to brush after you add bleach help mix it up faster. Do you think the stains might have been caused by the cal-hypo you were adding before you made the switch to bleach? Cal-hypo and other solid forms of chlorine can bleach a liner if it settles in one spot before dissolving. This is especially true with colder water.
Another idea is that you've overestimated the volume of your pool and which causes you to add more bleach than needed to get to slam level. You might want to double check you volume using these helpful calculators:
http://www.troublefreepool.com/calc.html
I am not too familiar with vinyl liner, but you might want to add a photo of the spots. I have a painted plaster pool and leaves don't fade, but cause dark stains.
To an extent, but still much less than would happen in an unstabilized public pool.Also, use old swimsuits because they can fade a little faster at SLAM levels.
