I literally can't tell what my CYA is because it looks different in every light. I have complained about it in here before but this time my question is related to slamming:
So when testing CYA, the little dot starts to disappear around 60 and in most settings I can still kind of make out the little dot around 50 but barely. Same thing when the level gets to 40. It looks like I can't see the dot and then I carry it inside and I can start to make it out. Why is measuring CYA so inexact?
So my question is, when slamming, let's suppose that the actual CYA is 40 but when reading it, I mistake it for 50. Am I doing any damage by using the slam chlorine level for 50 (24ppm) as opposed to the slam chlorine level for CYA of 40 (16ppm)?
I would assume that overshooting the minimum chlorine level for slamming would be safer than UNDERshooting the minimum chlorine level. Is this correct? That is, at the worst am I just wasting a lot of chlorine, or will the process not work with too much chlorine?
Thanks!
Thanks!
