Hi,
Sorry if this has been asked before.
I have a plaster pool 28,000 gallons. One of my skimmers has about .5-1 inch crack at the very top where it joins the top piece and is 1-2 inches long.
I don’t have a picture of it as I my pool is not open yet which I am going to open this weekend.
I need to get the deck replaced and the skimmer will also be replaced and I am planning to do it within the year so I realize this is a temporary fix.
In the meantime I am planning to patch it with two part epoxy but but since it is fairly big should I put any of foam backing that would be used when fixing mastic joints behind it or can I just use tge epoxy over it(or should I use silicone)?
Given the space I just want to see if it is needed with the epoxy as I never worked with the epoxy before or would the foam just fall through the crack and get in the way.
Thanks for any thoughts!
