I have a common 6x12 skimmer and a skimmer basket(maybe 8in around). Its an above ground 18ft pool. The skimmer has a basket that you can pull out and clean. When I vacuum, i used a skimmer plate with a 90degree hose connector and thats that. Attaching the hose to this connection while maintaining prime is a tricky, two handed process that seems to be always be almost above the water. It sounds like its sucking a little air. How do you make this connection easier without the risk of sucking air?
