This is my first time on a forum so I hope I'm doing this right. If I don't get a response then I'll know I did it wrong. My question is concerning my skimmer. My algae problem is so bad this year that a "normal" vacuuming will not work. I'm having to vacuum to waste. This is the first time I've had to do this. My problem is that water is being sucked out around the vacuum hose where it's connected in the skimmer. The end of my vacuum hose that connects to the skimmer is larger than the skimmer hole so I have to use an adapter to get it to fit. It feels like a good connection but it obviously isn't. Therefore, the water in the skimmer is sucked out which causes a loud sucking sound. My question is will this hurt anything other than having to listen to the noise. I can still vacuum the algae but, of course, the suction isn't 100%. I just want to make sure I won't damage my pump or filter by continuing. Thanks for any input.
