Everything is working fine as it is now. I have 4 skimmers on my 37500 gal pool. They are divided into North and South. There is a ball valve for the North and also for the South set. The ball valves will not turn. Do I need these ball valves? I have the 'flap' in the bottom of the skimmers to stop and or control water flow. I have the Jandy valve to control the flow between the skimmers and the main drain. Replacing the ball valves might be tricky because of the short pipe left available from the last installation
