I have a rudimentary x10 automation system that does three things:
1) turn on/off pool light
2) turn on/off spa light
3) turn on "spa mode"
Spa mode entails:
a) turn on Hayward 3/4 hp booster pump
b) switch outlet and inlet Goldline valve actuators to spa position
c) turn Hayward gas heater to spa mode
All this magic seems to happen inside a control box. I've attached a couple of photos of said control box below. I would like to know how this all works. I have a pretty good understanding of household electricity.
I have two light switches that control the pool and spa lights. I assume the x10 control module simply sends an on/off signal to these two switches to take care of function 1 and 2.
It's function 3 that I don't understand. The x10 module in the box is this: SmartHome - X10 Universal Receiver - Relay Output
The description says it responds by closing an internal relay. That one relay must control the pump, valve actuators and heater. How does that work? What sort of signal are the pump, valve actuators and heater expecting? Is this documented somewhere? I can't find a thing in either of my owner's manuals.
Spa mode entails:
