- Jul 7, 2020
- 97
- Plaster
- Jandy Aquapure 1400
I am losing all trust with our pool builder and I wanted to hear your opinion on two things that don't see right to me (but I don't build pools).
P.S. we are plastering the pool with Hydrazzo if that matters at all.
- The builder wants to plaster and fill the pool on Monday. No equipment is installed yet, I mentioned this and they said they could do a temporary pump to get circulation if they can't install the equipment before Monday. I am not sure what startup method is being used. I believe an Acid startup you don't run your pump for a few days. If it is a traditional startup I believe you are supposed to have your pump and filter running 24/7 right away for plater dust, right? Should I demand that they not plaster the pool until the equipment is installed?
- When are umbrella holders supposed to be installed? I thought this would happen before the shotcrete, but they insisted they are installed later. Obviously the pool have already been shot, but I would imagine they should install them before they plaster the pool, correct? The receptionist (her word is basically useless) said she believes they install the umbrella holders 45 days after the plaster has been installed because it needs to cure. To me (for whatever that is worth) seems incredibly dumb.
