Should I slam the pool again.
He he, that wouldn't be possible with my full time job. The most I can do is to check/add every night when I come home. But the weekend is coming up...
Thx
OK, so when you check/add every night you can't come back 30 minutes later and check once more?
That's a tough full time job you got there......
Dom
Hello amati,
I just completed a SLAM on my very gross pool, it took 19 days, and 76 gallons of 10% liquid shock to get it clean and clear. (Hopefully your pool will take less, but I just want you to know how long, and how much bleach it Could take).
My pool is only 15,200 gal which is less than half the size of yours. 1 gallon of 10% Liquid Shock was added to mine Several times a day, and I was just able to maintain the appropriate Slam/Shock levels.
The point I'm trying to make is I personally do Not believe that a mere 1 gallon of 10%, and especially a lower % of bleach, will be near enough to adequately maintain your 35K gallon pool at Slam/Shock levels all day while your at work.
Trust me, I totally understand when you are currently at Shock/Slam levels how confusing it can be to try to decide exactly how much bleach is enough to maintain your current level. If your levels are low then pool math will tell you to add X amount to increase to your Goal, but if you're on your goal already, it doesn't say how much is required to stay there.
So that's when you have to do some of the estimated calculations yourself. You have to take into account how much will one gallon of whatever percent you are planning to use raise your FC level, and then compensate for how much of the added chlorine the sun, and your 70 CYA, will eat back up in the process. Putting a cover on your pool during the day will help you not lose as much too.
In your case, since your FC level can't be checked but once a day you need to raise the number up during the time your away to prevent dropping below SLAM/SHOCK level while your at work. Then come home, check the levels, and add more bleach in the appropriate amount per http://www.troublefreepool.com/calc.html. to maintain 28ppm throughout the night. (which of course should be some less needed than during the day because there is no sun).
Here is the chlorine/cya chart http://www.troublefreepool.com/content/128-chlorine-cya-chart-slam-shock SWG pool ranges are at the bottom. With a CYA of 70 your pool needs to remain at Least 28ppm all the time.
I'm not certain on how high the level really needs to be to kill Black Algae, but I do know Black algae is one bad boy to get rid of, but here is an article that says you need to maintain the higher end of normal to the shock level of 28ppm in your case. http://www.troublefreepool.com/content/180-Black-Algae
Perhaps someone with a lot more experience than me can give you an exact levels on the black algae you are trying to kill, but I'd recommend you continue to shoot for at, or above the 28ppm range you are now at when you can check it often, and possible bump that during the day to a higher Goal range of say 31-32ppm to start when you Can't be there to routinely check it, and see how close that keeps you, and then adjust the amount of chlorine you add up, or down, accordingly the next time.
According to Pool Math to take you from your current 28ppm to say 31-32 ppm level will take close to a gallon and half of 10% and a little over a gallon and a half of 8.25% to get you there. If that doesn't hold you to at least 28ppm until you get home, then you may need to add 1 3/4 gallon-2gallons. You might want to just go ahead and add 2 gallons before work to see where your levels are upon returning home then adjust the level the next day accordingly? Only you can decide how you chose to add your chlorine, but I promise if the levels don't stay high enough, the ENTIRE TIME, the Slam will Not work properly.
(NOTE: THESE ARE GALLONS, so if you are using QUARTS of BLEACH etc you have to add more to =the full needed amount. Use POOL MATH to tell you how much you will need if using quarts etc.
(The important thing to remember is a SLAM can NOT be done properly playing hit and miss- (with FC levels up high, then allowed to drop way down low), you MUST maintain the appropriate level, or higher without ever going below the level, at ALL times during the entire SLAM, or you're merely wasting your time, along with a whole lot of money on bleach, and you'll end up not killing the algae, and having to start all over again). Doing it Correct the 1st time is way better than having to RESLAM multiple times.
And like Dom suggested you need to check those levels again at night 30-60 mins after adding the chlorine, and it will tell you a lot about what's going on in there, and how much chlorine your pool is actually consuming. If need be get started an hour earlier than you usually would.
(FYI-MUSTARD ALGAE takes 39ppm of FC on a SWG pool to kill it, and I suspect Black algae may be harder to kill then mustard algae from what I've read, so hopefully the 28ppm will be high enough to kill it, if not you'll need to increase the FC level more).
If you don't have a cover, or don't wish to cover it, and it gets a lot of direct sunlight then you Might have to compensate your levels up for that.
You should be able to get pretty close to knowing what you'll need to add after testing the 1st couple days. Again like Dom suggested you need to check those levels again at night 30-60 mins after adding the chlorine, and it will tell you a lot about what's going on in there, and how much chlorine your pool is actually consuming.
Doing this will get you to where you want to be quicker.
Anyway, I hope this helps get your SLAM started, and Maintained appropriately to get that black algae killed out once, and for all. Good Luck and Happy Slamming :)
UPDATE- If anyone is going to be swimming in the pool while you're at work, OR if you plan to swim in it on the weekend, you need to keep your FC level no higher than the suggested SLAM/SHOCK level (In your case with a 70 CYA, SWG pool that would be 28 ppm, so it can be swam in safely. After you finish swimming, then you can raise it back up higher than 28 ppm if needed, for the extended no check time at work, etc.
Thx, nothing is allowed in the pool for now despite the 100 degree temp coming this weekend. I have some solar rings that I didn't care to use but I'll throw them into the pool to partly block the sun light.
It's not something you Have to use it is just a suggestion that could help you not lose so much chlorine, and risk dropping below your SLAM/Shock level when you're not there to check it often. If you want to try it without it first, and see if you can adequately maintain your levels then that's fine. Either way will work.
Good Luck, and Have a Nice Night.
Ok, it looks like a sucess as of this morning.
-Water is clear with no visible black algea. With pebble pool, it's harder to see but it's clear. Actually it's been this way 3-4 days ago.
-No loss on FC overnight.
-No CC. I think the reason the CC took too long to clear up was because I left the vacuum in the pool and the hose and at least 3-4 sections of the hose, have visible algea inside that can be seen from outside (Kreepy Krauly).
I left the KK outside and filled the hose with the pool water (with high FC) everyday hopefully it will clear up soon but I am not sure since I can't brush it. My question is, is it a good idea to fill it with pool water or just leave it dry and let algae die off. Basically, how do I get rid of the algae inside the hose. I am scared to put it back in the pool and thinking of replaced those sections with new ones.
Thanks everyone for helping out with your advise/experience.
If your hose is in sections, I'd try a bottle brush on it, if you can reach the algae spots. The drain snake things with a brush on one end may work as well. Otherwise, I'd stuff an old sock in one end of the affected section (duct tape in place, if necessary) pour bleach in the hose and stop up the other end as well. Shake it up, roll it around then leave it laying with the bleach on the algae spots for awhile then dump it out. :)
Well done, Amati. When I was slamming mine, after I'd vacuum I'd pull the vac, hoses with the water in them out and drain them on the ground, instead of letting the vac hose water drain back into the pool just for that particular fear. I really didn't know if it did one bit of good or not doing it that way, but I didn't want to take the chance of returning algae from the vac hose back into the pool, just in case.
Thx for suggestion. I'll try that but If I can't remove dark areas out, I won't reuse that section. Don't want to go through this again. For the steps with black spots, I brushed and then pour chlorine over them and let it sit overnight with the pump turned off. I know I was supposed to let the pump run 24/7 during the whole process but doing this, I saw result instantly the next morning. It might have compromised the whole process but I think this is why the black algae on my steps gone much earlier.
I found something that I'd like to share or may be to be confirmed if it's true: When fill the tube with pool water, don't stick your finger in there to get rid of some water to lower to 10 ml. The test will show you have CC in the water :confused: I tested again the next morning (not touching the water) and my FC was double with no CC.
Also to update: I bought a duct cleaning tool to brush inside the hoses as recommended above and them sit in high chlorinated water over 2 days in the buckets. I was able to get rid of 99% of the dark spots. There is still a few inside the sleeve at the end of the hoses; I think because they are stuck in there but hope they are dead algae.
Thx
Hello, and Thanks for sharing that Amati. It is Very helpful information. Hope all is going well with your pool. Yes hopefully after a 2 day soaking and duct cleaning all the algae is dead. Be sure to clean your duct cleaning tool too after use. Whooo hooo!! Say adios algae. Have a wonderful day. :)
