- Mar 17, 2019
- 594
- Plaster
- CircuPool RJ-45 Plus
I'm trying to decide whether to drain my pool, now that the weather is cool enough to do so. Goal is avoid scaling of salt cell and pool waterline.
Here are my readings, taken today:
FC 8.0
CC 0.0
pH 7.6
TA 80
CH 850
CYA 80
Temp 54
CSI -.13
Yes, I could probably knock the CSI down a bit with lower pH and TA but with the lower temps right now I'm not that concerned. My dilemma is that when the weather warms up the CH will rise and the higher water temps will cause the CSI to rise as well. In summers past I've been as diligent as possible in trying to keep TA low by aerating and adding acid. This tends to keep CSI between -.2 and -.3.
I know that I really should have a softener on my auto-fill, but my auto-fill is plumbed off of my irrigation system, so connecting to my water home softener to it is not an option without some serious work. I have the auto-fill connected to my irrigation system because when we leave in the summer for a month or more I turn off the main water supply to the house. Only real option for me in this space is to install an RV softener and I'm not sure I want to mess with the manual regens but I would if it were worth it.
My fill water is typical for folks in the AZ deserts: 7.7pH/130TA/190CH. I drained the pool two years ago, but the CH seemed to creep up fast. Does it help to rinse the pool while draining (and before refiling)? Water costs are reasonable here as opposed to an RO exchange, so I would likely go that route.
FC 8.0
CC 0.0
pH 7.6
TA 80
CH 850
CYA 80
Temp 54
CSI -.13
