Hello. I installed a Calimar 3HP VSP pump and am trying to set the priming speed and duration. I have the updated controller for use with automation (CMARVSPIB). The pump runs just fine, however it primes at 3400rpm for 5 minutes every time it starts (manual or schedule). I haven't yet connected the automation. I'm using the schedule in the pump controller. The manual says to, (after letting the water drain from the pump)
"Turn on the pump and switch to Manual mode to test Priming by operating SPEED1. Take note of the time that the water filled the PUMP HOUSING, then stop the pump. Restart the pump to set the SPEED1/Priming duration."
So that's what I did, and of course, nothing changed. I've talked with the seller (PoolSupplyUnlimited) who referred me to the sales email at Calimar. I received a reply from Calimar with the section of the manual with the priming instructions above, which didn't help. I asked Calimar for more specific steps (like do I disconnect power too?), but they went dark. Is this like setting the clock, where you have a few minutes to set speed 1 after initial powerup (or long press some keys to enter "pump prime mode)? I have speed 1 set with the correct speed and duration for priming, but the pump still runs 3400rpm 5 minutes at each startup. Does anyone here know the specific steps to set the Calimar pump priming speed and duration with the automation controller? Thanks.
