- Jul 15, 2012
- 614
- Plaster
- Hayward Aqua Rite (T-15)
I have a newly refinished diamond brite pool and spa and starting to see some staining, generally on patches where the surface is not fully flat (and the stains are appearing on the indentations). I am thinking to add Jack's purple to deal with potential metals (I use well water - used Jack's blue when I started running pump after refinish). Read the label and it talks about measuring the sequestrant level in the pool Jacks test kit. Is this something people do relatively routinely or should I just assume I am starting from zero and add a monthly maintenance dose?
