At my swimming pool I keep having problems with the (Sugar Valley) peristaltic pump for the PH-min (sulphuric acid solution). Because the pool is located lower than the technical room, the pipes empty when the filter pump is off. With the negative pressure that is created, the sulfuric acid is sucked in when the peristaltic pump is stopped in certain positions. Replacing the rotor and peristaltic tube had no effect.
Has anyone maybe dealt with this problem and knows a solution? Or could a magnetic pump be the solution (do they completely close, even at negative pressure)?
Thanks for the help!
