Hi TFP team.
I'm back after 6 months of construction - tore out the old 1975 concrete behemoth pool, and built the pool & spa of our dreams. We couldn't be happier, other than the long time it took to build![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
New pool is approx 25k gallons, plaster, cartridge filters, and my previously used Circupool RJ-60 SWG. The builder started it up about 40 days ago, and I've been waiting until now to get my SWG going so the plaster could cure. The builder got me going to good levels, I switched to liquid chlorine to carry me over until the plaster cured, and then we have had an insane amount of rain here in TX, so a decent portion of my water has likely been replaced. The pool swallowed up 4 gallons of 10% bleach without blinking, so I suspect my CYA just got nuked with the rain.
I started adding salt this past Tuesday, and added more on Wednesday - Salt readings with my Taylor kit (and on the Circupool) are around 3000/3100 ppm. Fired up the SWG on Tuesday, and it started generating Wednesday morning as I approached 2800ppm. I've had to top off my CYA as the rain diluted it, with the final bolus going in yesterday to bring me into the 50s (I'm pretty sure I was down in the 10's after the rain).
Taylor test kit with an independent verification from Leslies has me at the following:
FC: 0.5
CC: Trace, maybe 0.2?
pH: 7.2
TA: 80
CH: 220
CYA: 50
Phosphates: 4000 (first time seeing this as I've avoided Leslie's in the past like the plague)
Salt: 3000
Our pump has been running at full steam since I filled the pool a month ago, and my SWG has been at 100% capacity since Wednesday. I did a pseudo OCLT by testing FC first thing this morning before the sun came up, and even with pump & SWG running overnight, I'm only at 0.5 FC. I just can't get it any higher. There are 2-3 tiny algae spots in the pool, unsurprisingly, but they brush off easily.
Why can't I get FC higher? Is it the phosphates? Is my salt not high enough to effectively generate chlorine? Help me TPF, you're my only hope.
FC: 0.5
pH: 7.2
TA: 80
CH: 220
CYA: 50
Salt: 3000
