Still learning with this pool. Hadn't realized I could reduce the pool pump running time during the "winter" when the temperature of the water dropped below 55 degrees, as the SWG would stop producing chlorine. Realizing this I went ahead and dropped the pump timing at 20 gpm to 5 hours instead of the 10 hours at 20 gpm it was at before.
Amusing a few days later the water temperature has gotten above 55 degrees so the SWG is again producing chlorine. The SWG is oversized so that I can likely produce enough chlorine even running at only 5 hours as opposed to 10 hours for now.
So now I'm at the other end of the of the dilemma. When to change the pump back to the 10 hours, obviously I'd love to hold out on this as long as possible to save some electricity, but want to keep the pool nice and clear. I'm thinking to go back to 10 hours maybe at 60 degrees or perhaps 65 degrees and then adjust the SWG accordingly, and I realize there's likely no specific rule, but figure it would make sense to do a sanity check.
Could of things learned this past year.
1. SWG stops generating chlorine at 55 degrees.
2. get FC up to 20ish before it hits 55 degrees to minimize having to get liquid chlorine.
3. based on my spreadsheet it looks like the pool water temp will be under 55 degrees for roughly 2.5 to 3 months.
4. When the SWG stops generating chlorine drop the pump timing down.
