- Jun 2, 2022
- 65
- Plaster
- Pentair Intellichlor IC-40
Good morning,
I’ve been running my pool/spa with my IPhone/Ipad Screenlogic app. Since the app is limited, I wanted to try settings using the Windows interface. i got the software loaded. Ran it as administrator the first time and it says system not found. I ran it without trying as administrator and it says connecting to system, but then it says “ERROR: Login rejected by gateway.“
Nothing shows up in Local Systems Box on the Windows interface.
I’m running Windows 11. Protocol adapter version is 5.2.738.
My IPhone/IPad apps connect with no problem both locally and remotely.
I can see the protocol adapter on my Deco app (my wifi mesh). IP address is 192.168.68.50.
I’ve tried a 3 push reset on adapter and a long push on the adapter.
The configure IP info button on the ScreenLogic Interface is grayed out, so I can’t set it manually.
Any ideas?
Thanks!
Any ideas?
Thanks!
