I got my ta to 80 and my new csi is -.3. If I go to 70 the csi will be -.38, should I stop at 80?Yay!!!! Now you can work on that TA! Do you have an easy way to aerate?
This is assuming a ph of 7.6 btw.
Sent from my SM-N910P using Tapatalk
What level should I go for? I live in Houston btw.When you add it is up to you. Adding it now will save you some on the chlorine so..........
Kim
In an earlier post, you indicated a daily loss of 1.5 ppm. That's not really very much and I would leave it alone.I have been losing a lot of fc, I see people say that you should not lose a lot in the winter.
The last few weeks it has been 2.5 per day. I will see how it goes now that I have adjusted to the lower cya.In an earlier post, you indicated a daily loss of 1.5 ppm. That's not really very much and I would leave it alone.
Your precision testing and adjusting of your water is admirable but don't over do it with unnecessary worry. What I see in your posts is that you have a nice pool and you are managing it successfully. Nice work.
