We are just starting to use our brand new above ground pool and we’ve noticed that our skin is extremely dry. I’ve read multiple posts that adding a little salt up to 1000 ppm can help with the dry skin but my pool is not rated for salt water. The problem is so bad that I’m thinking about putting salt in anyway. Do any of you have experience with salt in an above ground pool and have you seen corrosion happen at 1000-1500 ppm? My heater also has a copper heat exchanger so I’m a little worried about corrosion on that too.
The attached photo shows my water chemistry:
