So my liner has a bunch of leaks (I think it was too big depth and the prior owners glued it to the pool walls about 6 inches from the bottom - its got a wierd horizontal wrinkle there, and when I look behind it it's stuck to the wall at regular intervals...) and the wall has rusted and has a couple of small holes near the bottom.
I drained it to an inch or so to look behind the liner and see how rusted it is, and it's bad enough I don't want to use the pool or try to repair the walls.
That said, I don't want to buy a new pool now and put it up before fall, even an intex one is still a pretty chunk of cash to have it sit unused.
I'd like to leave this pool up until next year, with as little water in it as possible (right now its like 4 inches of green, because of storms that came after I got it just about empty), but I'm trying to figure out what's involved with not closing a pool/how little water can I leave in it safely...
The more water I put in, the more stress on the rusted wall, and anything over 6 or 7 inches is above the line of leaks, and that means water flowing over the rusted part.
Is 6 or 7 inches enough to give some support to the walls against wind? Should I plan on treating the couple inches with chlorine regularly?
Should I get a mesh cover, or not bother if I'm going to be trashing it in the spring, anyway? I'm concerned about letting it turn into leaf soup and just draining the sludge later? But I'm also not sure no water is good for putting even a mesh cover on it...
Images: one with lowest water was how drained i got it before rain (white is the bottom), more green water is it today, and the other picture is the rusty spots from the outside...
