Background:
Yellow is my existing light lines. Red are existing panels. Purple would be "new build".
- My existing line from my house load center to the pool pad was galvanized steel and has corroded. It needs to be replaced.
- My existing lights conduit is brass and still good.
- Today, I have no automation, but am open it to depending on cost.
- Abandon the corroded line from the house (200A) to the pad
- Add a subpanel in the garage (60A) to feed the pool and well pump.
- Run multiple circuits from 60A panel to equipment in conduit
- 20A GFCI 240v to Intermatic timer and pump (hot/hot)
- 20A GFCI 240v to heater/blower (hot/hot)
- 20A 240v to well pump (hot/hot)
- 20A GFCI 120v to lights (hot/neutral/ground)
- Add VSP Pump and SWG in future.
- Would it be better to run larger feeder wire all the way to the pad, and put subpanel at pad?
- If so, what kind of panel? One with automation?
- How do you transition from brass to PVC so I can extend my pool light circuit?
