Okay, so I would offer the following:
- If those test results were correct, there is nothing that would appear to explain which your shell would feel rough all of a sudden.
- If the FC is correct, it's too low and you run the risk of algae (not related to your original question).
- Accurate testing. Here at TFP we place very little value on free local pool store testing. Time & time again we see it flawed and the results are almost never consistent. We simply don't trust their tests and neither should you.
I understand that the roughness concern is your priority right now, and you have about 1.5 months or so left in your season, but I would highly encourage you to get your own TF-series test kit (link in my signature) or a Taylor K-2006C if you don't already have one. Accurate at-home testing is the only way to go and a test kit now should last you now and well through the next season.
At the moment, I'm just not seeing anything to explain the roughness. The only possibility is that there is indeed a chemical imbalance that is way off, but the pool store test numbers are indeed flawed and don't reflect it.
