Our PB says that we won't be able to use auto pool cover if we do a rolled edge (this is the image of the rolled edge I shared with the PB) for the spa (spa is inside the pool perimeter). The PB said that the rolled edge does not allow for room under the coping for the cover track. Instead, they are proposing what they call a "comfort edge" (photo attached) where the back of the bench is pulled out a little beyond the coping and then there is a little lip back before going up to the coping. Has anyone run into this issue where you can't do a rolling edge due to the pool cover?
