So I closed the pool today, but I am having second thoughts. Following directions, I drained the pool (Intex Prism 16'x48") below the lowest ports, plugged the ports and brought inside all hoses, including the after-market hayward strainer. I put a 4' pillow in the middle, tethered it on 4 points with somewhat loose lines and covered with a 15' cover (pool is 16').
The cover barely touches the water and I'm not sure switching up to a 16' cover would do the trick. The shape of the pool changed as the water volume is settling on the bottom. I'm just not sure it's safe.
I'm tempted to refill the pool and raise the level so that the cover rests on a more supportive surface. Thoughts? And if I do that, how high? I have 2 low-set water intake holes, 2' below the edge, as well as a cut-out for an after-market Hayward strainer, and the original return (just widened, same position).
I removed the strainer, blocked the return with a foam plug and screwed the frame into a flat piece of wood behind to support the shape of the hole.
Do I rise the water below the strainer or should it go above? Or leave it below the lowest hole and get a much bigger tarp?
I'll post some pictures in the morning.
