I currently have a 2-speed Hayward TriStar pump [SP3215EE] which is being replaced by a Hayward TriStar XE pump [SP3210X15XE]. I use my AutoPilot [7503] as the controller of the 2-speed pump. Whie the speed of the new pump will be controlled by the pump itself the power will still be running thru the AutoPilot.. I do however have a question on the wiring. The old wiring was set up on a 4-prong 230 line from the AutoPilot, green was ground, red[a] is low speed went to y on the plug, black[L1] is high speed went to x on plug, white[L2]is common power and went to w on the plug.
Now the new pump will be on a three-prong plug. Would I now wire this with both the red and black going to L1, white to L2, and ground to ground?
Thanks in advance forany and all help.
Daren
Daren
