Hey all.
When you get the recommend addition for a chemical, such as chlorine, where does the calculator try and land your outcome?
For example: I measured 2.0 FC yesterday and I added the recommended amount of chlorine and after 5 hours I got 7.5 FC.
Given my other pool test results, the recommended FC is between 4 and 8. Does the calculator try and push you to the high end of normal? Or does it shoot for the middle?
I ask because I don't actually know how many gallons my pool actually holds. The previous owner wasn't sure, even though he's the one who had it installed.
So if the pool calculator shoots for the middle and I got a high end, then I know my volume is a little less than what I'm currently estimating.
