At the beginning of the season I installed a Circupool Edge 40. It’s been great once I got the settings and runtime dialed in. Other than testing the water I almost never have to think about the chlorine side of my pool maintenance. FC is almost always between 5 and 7 ppm, and CC is usually 0, and at most is 0.5 ppm after heavy use.
The one issue I’m seeing though is, on occasion, one or two of my three return lines stop flowing because I believe the air bubbles produced by the SWG somehow block the flow. I started noticing it when the strongest jet closest to the pump seemed to stop flowing. I then can run the pump momentarily up to full speed and the one running jet discharges lots of bubbles and agitates the water pretty aggressively, returns to normal, then all three jets function normally. To combat it I programmed the pump to run at a higher speed to start the day, hopefully to clear out any air left from the previous day. This has mostly worked, but I still have seen it later in the day from time to time.
Anything I can do to correct it? Am I running my pump too low? Am I way off base to the cause of the flow issue? Should I be concerned? No leaks noticed on the return side, and no bubbles pump from the supply side.
Thanks in advance for any advice.
