Ok, maybe I’m worried over nothing but need some advice. The screw plate on my pressure side pool cleaner is cracked. Unsure if it’s leaking but want to replace anyway. The liner is only 3 years old but I’m worried that if i take the plate off, the vinyl might shift or stretch and I will be in trouble.
Any advice or experience on this? Also, are the threads typically the same size for a return jet on these pressure side ports? Thank you!
