A few years back had a spa added and installed an OmniPL system with ColorLogic in the spa. The pool itself already had a large light (non-led), but it only has one and my pool is still pretty dim overall. Also, it does turn on with the spa light through the app.
The pool equipment is probably 50+ feet away, however PB added Hayward transformer (LTBUY11300) 15 ft from the pool.
Anyhow, how difficult to retrofit 2-3 more ColorLogic lights.
I’m no stranger to electrical, remodeling, home renos, etc. and I have reworked some of my pool equipment plumbing and reprogrammed the OmniLogic system several times (I’m also an engineer).
Should these only really be installed with a new pool build? Or is it as “simple” as draining the pool a bit, drill a core, run pvc (to that white transformer box?), and done? How do I ensure a watertight seal?
TBH I don’t care if they are colorlogic lights. I just want white lighting in the pool.
