I’ve got 32x16 vinyl liner pool that I’ve established is not bonded. The pool was originally built in the late 60’s or early 70’sI believe and has been upgraded at various times (liner was replaced in 2015), but no one ever did any bonding.
As far as metal parts it has two metal ladders, one of which goes into the water. Also has metal coping. Those are the only metal parts near the pool that I know of. The pool
has no light. It does have a concrete deck around it but I have no idea if there is rebar in the deck. I also don’t know what the support walls are made out of but I may be able to contact the company that replaced the liner to find out.
Anyway looking it it wouldn’t be difficult to attach a wire from each ladder to the coping and then from the coping run #8 wire in the separation joint of the concrete and then under the soil over to my equipment pad.
So is this worth doing? Does it make it any safer than nothing at all? or is leaving out the concrete deck and possible metal walls from bonding making the situation worse?
