- Sep 24, 2014
- 154
- Plaster
- Hayward Aqua Rite (T-15)
I'm plumbing a new Hayward VS pump and SWG for my pool. I have 3 1.5" drains combining into a 2" pipe before the pump. Hayward recommends a 10" straight length of pipe into the pump (5x pipe diameter). I would like to put a ball valve on the inlet line, to make pump removal/servicing/priming easier in the future (pump has unions on inlet/outlet). Question #1, if I have 2" plumbing and a 2" ball valve, can I consider the ball valve part of my straight run? My engineering brain thinks "yes", but would love a second opinion to back me up.
I'm planning to do the entire pad in 2" PVC, where the previous pump and filter were done with mostly 1.5" plumbing. I expect much less head loss with the 2" fittings, allowing me to run the VS pump at a lower speed to get the same flow.
Other than the ball valve before the pump, I'm trying to decide if I need any others. Any maintenance benefit putting one between the pump and filter? What about around the SWG? At first I was thinking to put them everywhere, but now I'm questioning the benefit. When servicing the pool, if I close the inlet valve, shut off the pump, and open the filter, the water will gravity drain back to the pool, emptying the filter and SWG for maintenance. That's good enough, right?
The pool has two return eyeballs, and they are split underground off the same return line, so no valves to control/balance the returns.
