Hey everyone,
I started an old post about this in 2016, and it's finally time for me to act on it. I recently hired a PB to replaster my pool. It is an in ground pool from the 1980s, and well over due. They removed the plaster, and it turns out there were TWO layers of plaster. I believe the previous owner just replastered the pool on his own without removing the old plaster, in order that he can add mosaics, which came out pretty nice. Anyway, I mention this, because in addition to the mosaics and second layer of plaster, it is now very clear that they added concrete to reduce the depth of the pool. You can see very clearly where the concrete was poured in. There is a layer of plaster separating the concrete from the gunite, right?
Here is my question again. What are your thoughts about having them remove that filled in concrete? The demo team wants $3000 to remove it, because they said they are uncertain what's under it. To me, it seems like you just start jack hammering and using the layer of plaster as your guide on when to stop. This way, i can have my deep pool as it was originally intended. Also, they put in a fake drain and didn't bother to plumb it down to the original drain, so I'd like to restore that if it's recommended. I understand that there could be rebar, and maybe they did something to the original shell. Should I be concerned about all of that?
I appreciate all your thoughts, including why I should or should not have the deeper pool.
