- May 3, 2007
- 16,964
- Plaster
- Hayward Aqua Rite (T-15)
More than likely if the PB connected the two skimmers close to the pool to save some pipe.What's the chance that both skimmers tie in close to the one suction line right at my pool equipment? like i said a few posts ago, i plan to dig down and see if i can make them be on seperate lines to better control the suction of each skimmer.
What you are showing there is the eyeball, not the nozzle. The spa jet nozzle is deep within the spa wall:I have 4 jets, and when i measure the inside of the jet it is 1", the overall body size is 2 3/8". attached is a picture.
Based off of what I am reading my pump is not going to push enough water through that 2" pipe for all 4 of these jest.
should i reduce the size of the nozzel?
Nozzles are typically much less than a 1/2" in diameter. They look like this:
