I have to replace a Pentair Globrite (Shocker, I know!) but i was curious if I have to drain below the level of the light housing. I've had most of them repaired under warranty, but this one lasted through the warranty period so it's on me now. I recall watching the tech replace them and they drained the spa to replace the one in the spa, but they did the other one in the shallow landing while it was slightly submerged. The one I need to replace is about 3 feet under water. I know the housing isn't water tight so I'm assuming there is already water in the conduit going back to the equipment pad. And the J-box/connection box at the equipment pad is about 4 feet up the wall so the water level should be well below that. My plan was to kill the power to the equipment pad and just replace it without draining. I'll use a nylon pull string and attach it to the old light to help pull the new light through.
Any other suggestions?
