Hi all, i spent all day yesterday replacing my 2hp single speed pump with the Pentair VS superflo. It was hot for this year (mid 80s) and the pool had the cover on for the duration of my 6 hour replumb of my entire system with zero circulation.
Before I started the process, I took readings to see where I was and everything was in ideal ranges.
PH 7.2
FC 6
CC 0
CYA 60
TEMP 84F
I took the cover off in the hopes of going for a swim after, but our air temps dropped too fast for it to be fun. So...Overnight, (for some unknown reason) the levels all plummeted.
PH 8
FC 0
CC 4
CYA 0
TEMP 80
I ran them 2 or 3 times but each was similar reaults. I have spent the day trying to get things back in order.
-Added 6lbs of granulated stabilizer (i have a 9lb bin from Doheny that for some reason just falls apart in water so the socks are empty in a couple of hours.)
- Added required amount of Liquid chlorine to get FC up (1Gal + 1QT) but that obviously didnt stay because of the sun and no CYA yet.
- Added 1/2 Gal mutiatic acid to get PH down.
After CYA got to 30 on 2 tests 2 hours apart, I added 2 Gal of liquid chlorine (more than required by pool math) to get to SLAM level.
Now 2 hours past that, pool test is;
FC 6
CC 0
PH 7
CYA 30
TEMP 84.
Running an areator right now to get PH up a tad to 7.2. Will do an Overnight to see if I actually caught and killed whatever hurt me.
My question is this... if CC levels hit zero and FC levels maintain consistency overnight, how long should I keep at slam level?
PH 7.2
FC 6
CC 0
CYA 60
TEMP 84F
PH 8
FC 0
CC 4
CYA 0
TEMP 80
FC 6
CC 0
PH 7
CYA 30
TEMP 84.
