Hi,
I have a GRE FS500 pump+filter installed on my pool. In the last two years the pump started to fail to start. This year, before I open the pool, I replaced the bearings and sealings of the pump and now it is quiter and runs smooth however it keeps failing to start. When I opened the motor to change the bearings and sealings I noticed that there was water inside the motor and one of the bearings have a lot of rust. I think the motor windings may be affected by the water and are requiring more power to run.
I'll try to contact a local store to know how it would cost to rewinding the motor but If I need to replace the pump should I replace with another one from GRE or there are better brands without increasing the price too much like astrapool?
Thank you
Thank you
